Settings to note when developing CrowPanel ESP32 7.0-inch display v3.0 via ESP-IDF
Hi!
I am trying to develop DIS08070H: CrowPanel ESP32 7.0-inch display v3.0 using the arduino-esp32 component in ESP-IDF, and while following a YouTube tutorial, I encountered a problem where the LovyanGFX library was not working properly.
Following the instructions provided on the Wiki, I successfully set up ESP-IDF and managed to output “Hello, world!” to the serial monitor. However, even after modifying the code provided in the lesson to use the “Arduino as an ESP-IDF component” approach, I found that the LGFX object was not initializing properly and the begin() function of the LGFX object was returning false.
I tried various library versions over several days, but they didn't help much. I solved this problem today, so I'm sharing this information in case anyone else is experiencing a similar situation.
In my case, the problem was caused by not configuring the PSRAM settings in ESP-IDF. The Wiki didn't mention this, so I guess I forgot to configure it. If Elecrow happens to come across this post, I think it would be helpful to add information about PSRAM settings to the ESP-IDF tutorial.
The setup process is as follows. For reference, in order to match the library versions required by the Wiki, I used ESP-IDF version 4.4.7 and arduino-esp32 version 2.0.15.
Enter the settings screen by running
idf.py menuconfig
in the ESP-IDF terminal.
In the
Component config
>ESP32S3-Specific
menu, enable theSupport for external, SPI-connected RAM
option.
In the
SPI RAM config
menu that appears when you enable this option, change theMode (QUAD/OCT) of SPI RAM chip in use (Quad Mode PSRAM)
setting toOctal Mode PSRAM
. (This part is set differently depending on the HMI type. Please refer to Lesson 02 of the CrowPanel tutorial video.)
Additionally, please note that you must uncomment the following section in the root CMakeLists.txt of LovyanGFX (I used version 1.1.8 as required by the Wiki).
### If you use arduino-esp32 components, please activate the next comment line.
# list(APPEND COMPONENT_REQUIRES arduino-esp32)
And don't forget to include the PCA9557 file provided in the Lesson GitHub repository in your project!
Here are the specific versions I used.
ESP-IDF v4.4.7
https://docs.espressif.com/projects/esp-idf/en/v4.4.7/esp32/get-started/index.html
arduino-esp32 v2.0.15
https://github.com/espressif/arduino-esp32/releases/tag/2.0.15
LovyanGFX v1.1.8
https://github.com/lovyan03/LovyanGFX/releases/tag/1.1.8
I hope this helps. Thank you!
Oh, I see now that the relevant information is included in the Wiki! I will check the relevant settings and add them.
(https://www.elecrow.com/wiki/CrowPanel-ESP32-7.0-inch-with-ESP-IDF.html#menuconfig-setup-section)
Dear Minjun,
Thank you very much for your sharing.
Best regards,
Thanks for sharing this! Can you explain exactly how you configured the PSRAM settings in ESP-IDF to make it work? I’m new to this and would appreciate the step-by-step if possible.
