Need a Basic Working Example for Elecrow CrowPanel Pico 2.8" (ST7789)
I’ve tried every possible way to get the Elecrow CrowPanel Pico 2.8" display working, but I haven’t succeeded. I followed the tutorial, installed the libraries provided in the guide, but nothing works.
I managed to write something to the display, but only by using an ILI9341 driver instead of the ST7789 it’s supposed to have — however, the text appeared mirrored. Anyway, I deleted everything, started from scratch, and now I no longer have the “semi-working” code.
If I load the UF2 demo firmware, it works fine, but I can’t compile the demo myself.
Could someone please share a very basic, working example?
Eventually, I plan to try using it with LVGL.
  • Dear Soundmit,
    Thanks!
    Warm regards,
  • edited August 2025
    Dear Soundmit,
    In order to help you solve the problem, please provide the following information:
    1. Could you please tell me what the hardware version of your device is? Please check it on the back.
    1. May I ask if you are following our wiki tutorial (the link is provided below) to carry out the operation?
      https://www.elecrow.com/wiki/Pico_HMI_2.8-inch_Arduino_Tutorial.html
    2. Are you using the program we provided? Which program did you use? Did you successfully upload the program to the device?
    Thanks!
    Warm regards,
