Zigbee Startup Issue After Updating UZG-01 with Latest Z-Stack Firmware
After updating my UZG-01 to the latest Z-Stack firmware posted on github using the ZigStar Flasher, Zigbee is no longer about to start up on my UZG-01. I tried updating the firmware again and all I am getting is ERROR: Timeout waiting for ACK/NACK after 'Synch (0x55 0x55)' from the flashing software. As I am still able to connect to the UZG-01 web interface, I am able to check the console and see -> 55 55 show up in the log.
I have tried flashing it over HA using the ZigStar TI CC2652P7 FW Flasher add-on both via network and USB, as well as reflashing it over USB via my computer using the ZigStar Flasher on Windows. In all instances I am running into the same ERROR: Timeout waiting for ACK/NACK after 'Synch (0x55 0x55)' problem.
As it is, the device is completely unusable and I have to temporarily go back to my previous coordinator. Would you be able to assist with an exchange?
Thank you.
  • It sounds like the update might have caused a problem with the Zigbee device starting up. Have you tried resetting it or checking if the new firmware is fully supported? Hope you find a fix soon!
