Upgrading an older CrowPi2 for Raspberry Pi 5
Is it possible to upgrade an older CrowPi2 to use a Raspberry Pi 5 ?
There are several issues:
1. Is the power supply big enough? Apparently the newer CrowPi2 uses a USB C connector whereas the older one uses a barrel connector and the supplied power supply is rated at 12v 2 Amps. Obviously this is stepped down to 5 volts for the Raspberry Pi but will it supply enough current for the Pi5 ?
2. The Pi 5 heat sink and fan assembly is not compatible with the CrowPi2 and needs to be removed. Is the CrowPi2 cooling fan enough to cool the Pi 5 ?
3. The Pi 5 connectors are compatible with the Pi 4 but is the CrowPi2 wiring, connectors, and power supply heavy enough for the extra current requirements of the Pi 5 ?
  • Hi, Rovman,
    We are sorry that the old version of Crowpi 2 cannot be used directly with Raspberry Pi 5.
  • Is it the internal power supply?
    A bigger external power supply is easy.
    Hi, Rovman,
    It is not because of the internal power supply. It is because the core board was modified.
  • edited April 2025
    The J14 PoE pins on the Pi5 get in the way of the case.
  • Hi, it seems that the new version of Crowpi2 was released which is compatible with Pi5. I found an update on spec sheet on power port, upgraded to USB C instead of DC jack eliminated. Is there other changes ? and still not possible to upgrade old version ?
