You can use the fswebcam app to capture photos with the built-in webcam with a resolution upto VGA (640x480). For detailed usage, consult the Man Page (man fswebcam). Or the Raspberry Pi official documentation.
A quick example of taking a photo:
1) Open a new Terminal window (Ctrl+Alt+t).
2) Type the following command:
3) Post in front of the camera, when ready to take a photo, press Enter.
4) The new photo should be saved as Photo1.jpg in your home directory.
For additional explanation, you can view this short Youtube video.
On the quick example above in step 2, the output file 'Photo1.jpg' will be over written without prompting each time when a picture is taken.
Solution:
You can write a Bash script which takes a picture with the webcam and save it with a filename based on the current time. The example script below saves the images in the /home/pi/webcam directory, so create the webcam subdirectory first with:
mkdir /home/pi/webcam
To create a script named webcam.sh, open up your editor of choice and write (or copy & paste) the following example code:
This script will take a picture and name the image file with a timestamp. Say we saved the script as webcam.sh, we would first make the file executable:
chmod +x webcam.sh
Then run with:
./webcam.sh
Which would run the commands in the file and give the usual output:
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
No input was specified, using the first.
--- Capturing frame...
Corrupt JPEG data: 2 extraneous bytes before marker 0xd6
Captured frame in 0.00 seconds.
--- Processing captured image...
Disabling banner.
Writing JPEG image to '/home/pi/webcam/2022-06-21_143826.jpg'.
To take a photograph with the CrowPi2, use the built-in Raspberry Pi camera module. Open the Raspberry Pi OS, launch the camera application or use a Python script with picamera to capture images. Adjust settings for the best shot!
man fswebcam). Or the Raspberry Pi official documentation.A quick example of taking a photo:
fswebcam -r 640x480 Photo1.jpg3) Post in front of the camera, when ready to take a photo, press Enter.
Problem:
Solution:
/home/pi/webcamdirectory, so create thewebcamsubdirectory first with:To create a script named
webcam.sh, open up your editor of choice and write (or copy & paste) the following example code:This script will take a picture and name the image file with a timestamp. Say we saved the script as
webcam.sh, we would first make the file executable:Then run with:
picamerato capture images. Adjust settings for the best shot!
