DIS08792E : CrowPanel ESP32 5.79” E-paper HMI Display - What's the Power Consumption?
Anyone have any insight as to the power consumption of the 5.79" use cases below? I am trying to understand how big of a battery would be needed to have my device load an image once a day and then go into deepsleep.
- Power to initialize, clear, and display a new image (if there is any optimized power use code you have for this I would appreciate it).
- Power used for the device after the esp_deep_sleep_start() if run and remains in a deep sleep.
- Normal use while running the code to initialize and then update the image.
Hello,
Check out the test results at the end of the video
https://youtube.com/watch?v=vzq8-aMmTOQ&t=11s
Thank you! I do not think I saw that video playlist before.
