What actions should be taken to address the issue of excessive memory consumption by the UI
edited November 2024 in Elecrow HMI Display
Widgets and Screens:
1.Try to minimize the number of widgets and screens used in your project.
Fonts:
1. Try to minimize the number of different font types used
2. Minimize the generated font characters to only those you'll actually use - avoid unnecessarily generated characters. Use the Range and Symbols sections in the Font Manager.
https://docs.squareline.io/docs/dev_env/fontmanager#create-new-font
Images:
1. Try to minimize the number of images used
2. Avoid using images with alpha channels when possible
3. Where applicable, tile images that can be repeated. For example, instead of saving a divider line as a full image, save just a small section and adjust the widget size in the editor to determine the image size.
4. Try to use style effects rather than images wherever possible.
Memory Optimization:
1. Use the Temporary option in screen settings. When enabled, this loads the screen into memory only when it appears. It's recommended to enable this for all screens so only one screen loads into memory at a time, rather than the entire project.
https://docs.squareline.io/docs/widgets#screen
  • To address excessive memory consumption by the UI, minimize widget and screen usage, reduce font types and characters, limit image use and avoid alpha channels, tile images where possible, and prioritize style effects. Enable the "Temporary" option for screens to load them only when needed, optimizing memory usage.
    To optimize memory usage, focus on simplifying UI elements: use fewer widgets/screens, limit fonts and images, avoid alpha channels, tile images, prioritize styles, and enable "Temporary" screens for efficient loading.
  • edited January 30
    To optimize memory, streamline widgets, screens, and fonts while minimizing images and alpha channels.Use tiling, prioritize styles efficiently, and enable "Temporary" screens for better memory management and performance.
  • edited January 30
    Minimizing widgets, screens, and font variations while optimizing images and effects is a great approach to reducing memory usage. Enabling the "Temporary" option further enhances efficiency by loading screens only when necessaryThese steps collectively ensure a smoother UI experience with lower resource consumption.
    It’s definitely frustrating when such a basic feature isn’t available, especially for premium users. Handwriting directly in the app would offer a much smoother experience, and it’s surprising it hasn’t been added despite demand. Hopefully, the developers will listen to feedback and introduce this feature soon, as it would make journaling feel more natural and intuitive.
  • edited March 5
    When such a fundamental service is unavailable, it is undoubtedly annoying, particularly for premium members. It's strange that handwriting hasn't been included despite desire because it would provide a much smoother experience. This feature would make journaling feel more intuitive and natural, so maybe the devs will take the suggestions into consideration and release it soon.
  • Excessive memory consumption by the UI can slow down performance and affect user experience. Optimizing resource usage, reducing background processes, and improving memory management can help. If you're looking for a free streaming app that runs smoothly without unnecessary memory drain, check this out!
  • Starbucks also emphasizes
    ethical sourcing and environmental sustainability, with a commitment to fair
    trade practices and reducing its ecological footprint. The brand is known for
    its distinctive green logo and a menu that caters to a wide range of tastes and
    dietary preferences.
  • Ayrıca, trafik yoğunluğunun en çok yaşandığı noktalarda oluşturulacak yeni bağlantı yolları ve ek duraklar, büyük ölçüde ulaşımın yükünü hafifletecek. Metrobüs Durakları 2025 projesi kapsamında, örneğin Avcılar, Zincirlikuyu ve Altunizade gibi noktalarda çok daha fazla otobüs ve minibüs hattıyla entegrasyona gidilmesi bekleniyor.
  • The user experience may suffer if the user interface uses too much memory. Improving memory management, cutting down on background processes, and optimizing resource utilization can all be beneficial. Check this out if you're searching for a free streaming program that functions well and doesn't use up too much memory.
