CrowView Note and Raspberry PI 5 Bridge support for additional HDMI screen display
How can you attach/connect an additional HDMI Display to a CrowView Note that is using the Raspberry Pi 5 Bridge Connector?
  • edited January 2025
    No, there is no method to connect a 2nd HDMI Display through the Raspberry Pi 5 Bridge Board, because the Micro-HDMI connector (J102) is just a dummy connector and does not pass any signals from the HDMI1 port of the connected Raspberry Pi to anywhere.
    If you wish to connect a 2nd HDMI Display, skip using the Raspberry Pi 5 Bridge Board, and make all your connections by cables
    • HDMI to Micro-HDMI x1 (For your 2nd HDMI Display)
    • Mini-HDMI to Micro-HDMI x1 (CrowView Note Display)
    • USB-C to USB-C x1 (CrowView Note left side USB-C Power output)
    • USB-A to USB-A x1 (CrowView Note left side USB-A for Keyboard and Touchpad)
    p.s. You can read comments on this subject at the original Kickstarter comments page.
