Where can I find /dev/sda?
I have entered a SD card in the SD card slot for additionnal storage.
Where can I find this SD card? If I try to mount it in a terminal it says that it is already mounted but I don'f find where?
  • edited August 2023
    Hello, You can find the SD card in the location indicated by the image. Please refer to the image.
  • I think it should be /dev/sdb since external devices on linux for me are always mounted like it , don't know about your setup but I think utilities like gparted will do the trick for you.
  • The microSD slot on the Pi is assign as mmcblk0. To locate the mount point on your system, open a terminal and use the command lsblk to display its mount point.
    Below is an example on my system:
    pi@rpi:~ $ lsblk
    NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
    sda           8:0    0 465.8G  0 disk
    ├─sda1        8:1    0   256M  0 part /boot
    └─sda2        8:2    0 465.5G  0 part /
    mmcblk0     179:0    0  29.7G  0 disk
    ├─mmcblk0p1 179:1    0   256M  0 part /media/pi/boot
    └─mmcblk0p2 179:2    0  29.5G  0 part /media/pi/rootfs
  • @pearl ,
    really appreciate it ,Thanks bro.
  • Thanks @pearl,
    you are a saviour to me. Thanks my friend.
  • Thanks @Pearl and also to the op.
    These things always confuse me. I really appreciate the help.
  • edited December 2024
    You can find /dev/sda on Linux systems as it represents the first SATA or SCSI storage device, usually your primary hard drive. To locate it:
    1. Using Terminal: Open the terminal and type:
    lsblk
    This will list all storage devices, including `/dev/sda`. 2. **Check with fdisk**:
    sudo fdisk -l
    This shows detailed information about your storage devices.
    3. File System: /dev/sda is typically in the /dev/ directory, which contains device files.
    Be cautious when accessing or modifying /dev/sda to avoid data loss.
    You’re a lifesaver! Truly grateful, my friend. Thanks!
  • You can find Dev-SDA resources in developer communities or through specific forums related to your tech stack. If you're into modded apps, like Nulls Brawl APK, you might check modding communities where similar resources and tools are shared.
This discussion has been closed.
