Home Assistant and GrowCube
Tried to follow your explanations to connect CrowCube to Home Assistant.
Setup of Home Assistant was ok. Updated the IP-Adresses.
But the auto-search function didn't find my GrowCube.
Does anyone have any suggestions?
Hello there.To begin, you need to download the latest app (currently version 4.0) from the Google Play Store. Afterward, you can upgrade the hardware firmware by adding the device in Direct Connection mode. Please note that the networking mode requires a hardware upgrade before it can be used.
You mean a firmware upgrade, not a real hardware upgrade, do you?
yes, I mean a firmware upgrade. Sorry for the incorrect expression before.
It sounds like you're on the right track with setting up Home Assistant and updating IP addresses. If the auto-search function didn't find your GrowCube, try manually adding the device by entering its IP address in the integrations section. Also, ensure your GrowCube is on the same network as Home Assistant.
