DIS08070H : CrowPanel 7.0" HMI ESP32 Display - TOUCH ISSUE
edited February 2025 in Elecrow HMI Display
So i got a new crowpanel 7 inch V3.0 display with touchscreen and tried to learn the basics through their youtube tutorial but one the 4th lesson i was stuck because the code did upload successfully but i wan unable to draw anything so if someone else has encountered similar issue kindly help me out. (I also checked the panel by uploading the default LVGL interface and the touch did work there so i think the error is in the code or the code provided in lesson 7 .)
  • Dear Soumya,
    Please try to change these two parameters from the original code and see the result.
    If still not working, please use this attached example code,it's mostly the same, just modified the libraries.
    If you have any further questions, please don't hesitate to let me know.
  • see other comment the paint program give me a black screen. your posting above does not match the revised schematic for pin numbers and address for the PCA9557 chip
    @Soumya
    How to upload the default LVGL interface please provide code
  • I tried the paint demo code above, and it works, but only for the bottom half of the screen
    Onlt responds when y > 215. Almost there!
  • Any ideas why the demo code only kicks in at y >= 215 ?
    I changed the I2C address to 0x5D from 0x14 and also the port from 1 to 0 and it still works the same
