USB serial adapter compatibility
Hey folks,
I wonder if the CrowView Note 14 is compatible with any USB-to-serial adapter cables on its USB-A port? I would like to connect to a system that only has exposed RS232 instead of USB.
Thanks in advance!
USB serial adapter compatibility depends on the chipset (like FTDI, CH340, or Prolific), driver support for your operating system, and the device you're connecting to. Always check for updated drivers and OS support before buying
Dear wiredOr,
Thank you for reaching out.
Thanks! Have a good day!
Dear wiredOr,
Sorry for the late reply.
What kind of system is the system you mentioned specifically ? How do you plan to wire it with Crowview note? What functions do you need to achieve? Please provide as much detailed information as possible so that we can further help you solve the problem.
