CrowView Note - No Signal
I just got a new CrowView Note. The RPi5 has a new RPi OS and then been booted and configured. I assembled the RPi5 with the included boards. Turning on the CrowView shows an battery symbol that is full, a message appears centered on the screen, CrowView Note, then a popup saying ‘No Signal’, finally, a message power saving and shuts off.
Any comments, questions or suggestions would be appreciated.
Thanks you,
Bill
The RPi5 isn’t getting any power from the CrowView.
Please troubleshoot the issue though these steps:
1.Did you turn the switch on?
2.Please make sure that your bridge board is fully inserted into the Note's port to avoid no signal due to loose connection.
3.If you have cables,please connect the cables to check if the bridge board problem.You can use the traditional cable connection method. USB-A to USB-A cable; 2. Mini HDMI to Micro HDMI cable; 3. Type-C to Type-C cable.
4.Reboot the CrowView Note.
If you have any further questions,please feel free to contace me!
