Connecting a Rpi directly
I'm trying to connect a Rpi4 directly (without using the special board) i.e.: charger to power supply, micro to mini HDMI (using the adapter that comes with the Crowview Note) USBA to USBA cable.
When I turn on the Rpi4 on the Crowview screen I can see the loading screens, then when it should show the desktop I only see a black screen.
Any help?
It seems that your system is stuck and not fully running.
If the system is stuck after starting and only shows a black screen, it might be that the operating system hasn't fully booted or there's an error. Here are some steps to troubleshoot:
1. Reboot the Raspberry Pi
If the system is stuck, first try rebooting the Raspberry Pi by unplugging the power, waiting a few seconds, and then reconnecting it to see if it can boot properly.
2. Check the SD Card and Operating System
If the operating system hasn't booted correctly, there might be an issue with the SD card or the OS files might be corrupted.
Try inserting the SD card into another computer to check if the file system is intact. You can try re-flashing the latest Raspberry Pi OS onto the SD card.
Visit the Raspberry Pi official website to download the latest image and reflash the SD card.
