roycejp
roycejp
About
- Username
- roycejp
- Joined
- Visits
- 35
- Last Active
- Roles
- Member
BTW did you use the old lessons with the new library, or the new lessons ? I would be happy if I could just get the simpler old lessons working.
I tried to link the discussion, but it seems i'm not allowed to do that. The discussion is: "Strange Error when compiling Lesson 4 (Drawing board) 7 inch V3.0" Its around the 10th from the top.
Hi, Thanks a lot for replying. I have created a new discussion for my issues. I have posted my results for (new) lesson 4 there. Can you please check out my update there? Thank you!
I Created a fresh arduino workspace and copied all the libraries there. Then I copied the 'crowpanel-esp32-7.0-3.0-touch" folder from the new course material (lesson 4) to here. Ram & Partition scheme is setup as instructed. When I compile…
Is anyone from Elecrow support reading this forum?
Hi, Could you get any of the demo code working ? Maybe the GIU or Drawing board Demo ? Even after the solution you discovered, I still get errors during compile.. May I request you to send any of the demo code (not your main code) working for you? I…
Please, can someone send me a working example (just one of the demo codes) working on the 7" HMI ? Thank you!
I tried various things (replacing the gfx_conf.h with the 'new' version, installing GT911 libraries etc..) but each time I get a new error about some file not found .. I'm stuck. Please help.
