roycejp
roycejp
About
- Username
- roycejp
- Joined
- Visits
- 35
- Last Active
- Roles
- Member
I found the issue. I need to use Wire1 instead of Wire. Unfortunately,this mentioned NOWHERE in your documentation.
So there is no way one can use touch AND any I2C peripheral?
@Linnalahti Did you manage to solve your issue?
I'm facing a similar issue with BH1750 sensor I dont understand this... When the display connector clearly has SDA = 19, SCL = 20, how can one connect to 21, & 22 as @lucymariee suggest? These pins are not available at the display connectors!!
so for some reason it knows my libraries folder, but not seeing the files inside the folders ?
I get this error with the touch program: Library Wire has been declared precompiled: Using precompiled library in d:\OneDrive\ESP32-ELECROW\libraries\Wire\src\esp32s3 Library lvgl has been declared precompiled: Precompiled library in "d:\OneDri…
Hi, SKU DIS08070H Purchase Site: ROBU **dot **in. I am not allowed tp post any links I seems. How to send you a link?
What does this error mean? I have rechecked the board, Ram & partition settings...all OK. error: Invalid FQBN: getting build properties for board esp32:esp32:esp32s3: invalid option 'ZigbeeMode' Compilation error: Invalid FQBN: getting build pr…
I finally managed to compile the 'draw.ino' project without errors, but the screen is blank (dark). Do I need to change any settings ?
Can you just help me to get lesson 2 (Draw.ino) working ? My version is 3.0 I'm already using the new libraries provided. Thank you!
