oliver
oliver
About
- Username
- oliver
- Joined
- Visits
- 98
- Last Active
- Roles
- Unconfirmed, Member
I managed to reflash with original provided firmware . So thank you but we can close this issue but i have a different question . Can you provide information on hoq to use the imagetools module in MicroPython v1.19.1-881-gcae7a7c73-dirty on 2023-10…
Having adjusted to the correct PINs i encounter WAV files are not playable via I2S neither STERO nor MONO . It crashes with Guru Meditation Error: Core 1 panic'ed (IntegerDivideByZero). Exception was unhandled.
By the way even the sample code in the Tutorial "Play music" throws the error "Invalid Pin"
