lamuce
lamuce
About
- Username
- lamuce
- Joined
- Visits
- 13
- Last Active
- Roles
- Member
As I see inside lv_conf.h there is a timer to refresh the screen. /Default display refresh period. LVG will redraw changed areas with this period time/ #define LV_DISP_DEF_REFR_PERIOD 30 /*[ms]*/ My idea would be to disable the timer, write to …
Hi Jennie, Thanks. That's what i'm doing. To make sure, I've added a 1 second delay after writing to the flash and before refreshing the screen. With the same result. I attach the code.
