Rovman
Rovman
About
- Username
- Rovman
- Joined
- Visits
- 51
- Last Active
- Roles
- Member
Is it the internal power supply? A bigger external power supply is easy.
I am starting a new thread "Upgrading an older CrowPi2 to RaspberryPi 5"
Yes. There is another issue and I solved the problems: 1. Use a bigger SD card than 32 GB. I used a 128 GB. 2. Expand the OS after the first boot up. It is described on this forum. 3. The updates installed OK. Do not switch to labwc as recommended. …
I solved the problems: 1. Use a bigger SD card than 32 GB. I used a 128 GB. 2. Expand the OS after the first boot up. It is described on this forum. 3. The updates installed OK. Do not switch to labwc as recommended. It might work for a normal Raspb…
DC barrel plug. I solved the problems: 1. Use a bigger SD card than 32 GB. I used a 128 GB. 2. Expand the OS after the first boot up. It is described on this forum. 3. The updates installed OK. Do not switch to labwc as recommended. It might work f…
I have the same problem
Thanks, I am using the download without modification on a 32 GB card and it works OK. I will pick up a 64 GB in a few days and try it, I can't buy them locally.
Has anyone successfully used this download and updated it? Can I buy the OS on a micro SD card?
I managed to install about half of the updates but the CroqPi2 became more unstable. Now there are 250 left and I get "Fail to Process Request" when trying to install just one (e.g. "Mathematica and the Wolfgram Language" or Enu …
I flashed the 64 bit image but it will not take the over 500 updates. It says there are over 2 GB of updates unless I deselect the bottom few. The 32 bit version eventually took them all. Neither one is the same as the OS that came with my CrowPi2, …
