How to disable the Crowpi2 software from autostart at bootup?
Remove the 1.desktop file from the ~/pi/.config/autostart folder.
- Press Ctrl+Alt+T, a new Terminal window appears.
- At the command prompt, type
mv ~/pi/.config/autostart/1.desktop ~/
and press Enter.
Note: If you change your mind later, just move the file back into the ~/pi/.config/autostart folder.
Had no success with the posted link. Went to the autostart folder and found CrowPanel. Should I substitute this file for 1.desktop?
Hello @gilwood ,
You only need to move the 1.desktop file out of the home/pi/.config/autostart folder.
There's a mistake in the command posted before. You should run
mv home/pi/.config/autostart/1.desktop ~/
ormv ~/.config/autostart/1.desktop ~/
in the terminal.After that the 1.desktop file will be moved to /home/pi directory. Then reboot the CrowPi2, the software will not automatically start any more.
PS. You can click "menu"→"Education"→"CrowPi2" to start the software.
