Growcube pump not sucking?
It thinks it's empty because there is no water going through but the pump sounds like it is going but no water movement happens.
I had a hose in and it had been working for a while but today I filled the container instead to see if that was it, and it still thinks it's empty.
I wonder if it's gunked like my years-ago aquarium pump used to be?
I see some algae in sections of the input hose - maybe the green got into the impeller?
Someone from Support or whatev pls comment before I go digging and voiding my warranty lol
Hello @pippi ,
It looks like something got into the water pump and caused it to become clogged. Please send your order number and question edit email to info@elecrow.com. Staff will handle follow-up questions for you.
In addition, please install a filter at the water inlet of the hose when you use it later to reduce things entering the water pump.
ok thanks!
