What's the proper voltage for using the battery connector for power instead of the USB?
Thanks,
Tim
Hello @jjtimo
5 volts would be good.
@admin Perfect! I figured but I just wanted to make sure!
I forgot also to ask what is the size of the battery connector?
Hi Tim,
The type of the battery connector is PH2.0
Best regards,
Elecrow TS
Thanks!
Ah, so, just to verify, directly connecting a ordinary 3.7v lithium battery to BAT won't be sufficient, is that right? Thanks!
--John
Hello Riney, You can safely use a 3.7V lithium battery for power supply. It is compatible and will function properly.
Hello @jjtimo
Thanks,
Tim
Thanks,
Tim
Hi Tim,
Best regards,
Elecrow TS
Thanks!
Tim
--John
