RC070 7" LCD Display stopped working - SPI Flash
(Double post in the correct section as I cannot move the actual post - sorry for that)
Hi guys,
i have a problem with my 7" LCD Display ( 1024X600 Touch RC070 ). I used to use this screen with a tiny PC running ubuntu and it worked fine until it suddenly stopped working.
The touchscreen still works fine, but the panel stays dark (no picture or backlight at all). I measured all power rails and it seems there is voltage on all rails.
Then i measured the data transfer on the small SPI Flash and it seems that this flash does not respond, so I desoldered it and checked it with an spi flash reader. Unfortunately it could only some parts or sometimes nothing. So I assume that this flash is broken.
If I replace that chip I would need the firmware/hex file on that chip. Is the firmware running on this chip somehow available so I can repair my display?
Please see the picture attached.
Thanks for any help!
Hi asdf_man,
Thank you for your patience in troubleshooting the issue.
We apologize, your question requires further analysis by our team. We will respond to you as soon as possible once we get the result.
We apologize for any inconvenience this may have caused.
Thanks! Have a good day!
Warm regards,
Hi asdf_man,
Sorry, we don't have that document at the moment. However, we'll look for it and get back to you when we find it.
ALso, Is your product still under its one-year warranty?
Best regards,
Hi asdf_man,
It might not be a chip issue; please try replacing the HDMI cable.
Best regards,
Hi Jennie,
thank you for you answer.
Unfortunately, it's 2 years since I bought it. I'm quite sure it is the spi-flash or another hardware fault. Of course I checked it with different cables, but thank you for your time.
Best Regards,
Hi asdf_man,
Thank you for your reply. We'll look for the file you need again. I'll get back to you as soon as I find it. I'm not sure if we can find it. so please be patient and wait.
Thank you!
Best regards,
