yes the SKU-Dis08070H
OK so what is when I had this I had the demo on it brand new, I tried to set it up and it went blank. Ever since I can get the back light to come it seems to be blue That is absolutely all I get. But if I hook it hook it up to my laptop everything's there. And I don't believe I have the factory framework. And thank you for responding back. Ever since I took the demo I have had zero luck with anything to perform on the ESP32 itself 7 inch
Hello,
I’m working with a CrowPanel 7.0 HMI ESP32-S3 unit and I want to confirm I’m following the correct factory restore / flashing process.
I successfully downloaded the package labeled hmi7.0-factory-firmware-3.0, but the contents appear to be Arduino source code (example → Arduino → arduino_code) rather than precompiled .bin firmware files.
Before proceeding further, I just want to confirm:
Is the intended factory restore method to open the provided Arduino .ino project and upload it via Arduino IDE to the ESP32-S3?
Or is there a separate set of factory .bin firmware files intended to be flashed using the ESP32 Flash Download Tool?
Right now I can see and open the Arduino source correctly, but I want to be sure I’m restoring the panel exactly as intended for my specific SKU before flashing.
If there is a recommended board profile, partition scheme, or specific Arduino settings for this panel, please let me know.
Thank you for your help — I appreciate it.
Best regards,
James Hart
If the ESP32 V3.0 touchscreen or Lesson 4 touch code fails, upload the provided fix code and make sure you are using ESP32 core version 2.0.x, since touch may not work correctly on 3.0+.
@james251 said:
Hello,
Best regards,
James Hart
Hi James,
This is the factory firmware: Pls choose the factory firmware according to the hardware version of your device.(It is on the back of the board.)
https://github.com/Elecrow-RD/CrowPanel-7.0-HMI-ESP32-Display-800x480/tree/master/factory_firmare
An example of a hardware version of HMI devices :
Hello,
Best regards,
James Hart
Dear James,
The link I provided earlier contains .bin files; please take a look. It also includes instructions. Just follow those steps.
Thanks, Best regards,
