ThinkNode M5 & Meshastic 2.7.14.e959000 Alpha: invalid header: 0x�ESP-ROM:esp32s3-20210327
Hi everyone,
I used the Meshtastic Webflasher to upgrade my ThinkNode M5 firmware to version 2.7.14.e959000 Alpha. After flashing, the device no longer boots. When I connect via serial console, I see the following output:
Build: Mar 27 2021
rst:0x10 (RTCWDT_RTC_RST), boot:0x2b (SPI_FAST_FLASH_BOOT)
invalid header: 0x3a343034
Has anyone run into this issue before?
Any guidance on how to recover the device and get it working again would be greatly appreciated!
Dear Customer/Sender,
Best regards,
Dear deadbeef ,
Please try to flash the device to the stable firmware version.
Thanks!
Warm regards,
Hi Jennie,
Order number: 262321 (purchased directly from the Elecrow store)
SKU: ILM13205D1
Could you please advise if there is a stable version of the metastatic firmware available for SKU ILM13205D1?
Thank you for your assistance.
Best regards,
Luka
Dear Luka,
The firmware of this device was developed by the meshtastic team in collaboration with us. Generally, if the meshtastic website indicates it as a stable version, it means it is stable. Please use the latest stable version.
Thanks.
Warm regards,
Hi Jennie
Just tried.. same problem.
Flash log:
then bootlog:
Dear Customer ,
Best regards,
Hi
Here is the info:
ThinkNode M5 Meshtastic (LoRa) Signal Transceiver |ESP32-S3 | 1.54” Screen | GPS Function
SKU: ILM13205D1
Order #262321
Do you need anything else?
Dear Customer,
Sorry for the late reply.
We've tested it and it works fine. Was your device functioning correctly before these 2 firmwares was flashed? This log shows the device is constantly restarting. Please try flashing the firmware again.
Thanks! Best regards,
