[CrowPanel Advance 7.0-HMI ESP32] Audio output & TF card usage.
I want to use that display as an audio player where the music is read from the tf card and played via I2S and the amplifier. I am confused if this is supported or i cannot use both options at the same time?
The function switching lists the following:
S1 S0 effective function
0 0 MIC&SPK
0 1 WM(wireless module)
1 0 TF Card
1 1 MIC&TF Card
Thank you for your help!
  • Dear aem,
    Thanks! Have a nice day!
  • Dear Aem,
    We are Sorry, the audio output and TF card usage cannot be used at the same time.
    Best regards,
  • From that config table, it looks like TF card and speaker output aren’t active together in the same mode. TF card modes pair with MIC, not SPK, so you can read music from the card but not output it over I2S/amp at the same time by default. You may need custom firmware or a different pin mapping to make both work together.
