ThinkNode M5 & Meshastic 2.7.14.e959000 Alpha: invalid header: 0x�ESP-ROM:esp32s3-20210327
Hi everyone,
I used the Meshtastic Webflasher to upgrade my ThinkNode M5 firmware to version 2.7.14.e959000 Alpha. After flashing, the device no longer boots. When I connect via serial console, I see the following output:
Build: Mar 27 2021
rst:0x10 (RTCWDT_RTC_RST), boot:0x2b (SPI_FAST_FLASH_BOOT)
invalid header: 0x3a343034
Has anyone run into this issue before?
Any guidance on how to recover the device and get it working again would be greatly appreciated!
  • Dear Customer/Sender,
    Best regards,
  • Dear deadbeef ,
    Please try to flash the device to the stable firmware version.
    Thanks!
    Warm regards,
  • Hi Jennie,
    Order number: 262321 (purchased directly from the Elecrow store)
    SKU: ILM13205D1
    Could you please advise if there is a stable version of the metastatic firmware available for SKU ILM13205D1?
    Thank you for your assistance.
    Best regards,
    Luka
  • @deadbeef said:
    Hi Jennie,
    SKU: ILM13205D1
    Best regards,
    Luka
    Dear Luka,
    The firmware of this device was developed by the meshtastic team in collaboration with us. Generally, if the meshtastic website indicates it as a stable version, it means it is stable. Please use the latest stable version.
    Thanks.
    Warm regards,
  • Hi Jennie
    Just tried.. same problem.
    Flash log:
    esptool.js
    Serial port WebSerial VendorID 0x1a86 ProductID 0x7522
    Connecting...
    Detecting chip type... ESP32-S3
    Chip is ESP32-S3 (QFN56) (revision v0.2)
    Features: Wi-Fi,BLE,Embedded PSRAM 8MB (AP_3v3)
    Crystal is 40MHz
    MAC: 30:ed:a0:31:bb:00
    Uploading stub...
    Running stub...
    Stub running...
    Erasing flash (this may take a while)...
    Chip erase completed successfully in 0.787s
    Not changing the image
    Compressed 16 bytes to 24...
    Writing at 0x0... (100%)
    Wrote 16 bytes (24 compressed) at 0x0 in 0.012 seconds.
    Compressed 506704 bytes to 309044...
    Writing at 0x260000... (5%)
    Writing at 0x26abbd... (10%)
    Writing at 0x279dd4... (15%)
    Writing at 0x27f920... (21%)
    Writing at 0x285293... (26%)
    Writing at 0x28a706... (31%)
    Writing at 0x28fd59... (36%)
    Writing at 0x295594... (42%)
    Writing at 0x29a8ed... (47%)
    Writing at 0x29ff84... (52%)
    Writing at 0x2a57ae... (57%)
    Writing at 0x2aaef0... (63%)
    Writing at 0x2b02a9... (68%)
    Writing at 0x2b59ec... (73%)
    Writing at 0x2bb0cf... (78%)
    Writing at 0x2c0952... (84%)
    Writing at 0x2c9cf8... (89%)
    Writing at 0x2d0fa8... (94%)
    Writing at 0x2d6a46... (100%)
    Wrote 506704 bytes (309044 compressed) at 0x260000 in 27.442 seconds.
    Writing at 0x300000... (100%)
    Wrote 16 bytes (24 compressed) at 0x300000 in 0.011 seconds.
    Leaving...
    then bootlog:
    invalid heade�ESP-ROM:esp32s3-20210327
    Build:Mar 27 2021
    rst:0x7 (TG0WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
    Saved PC:0x40049b21
  • @deadbeef said:
    Hi Jennie
    Flash log:
    esptool.js
    Connecting...
    Crystal is 40MHz
    Uploading stub...
    Running stub...
    Stub running...
    Leaving...
    then bootlog:
    Build:Mar 27 2021
    Saved PC:0x40049b21
    Dear Customer ,
    Best regards,
  • Hi
    Here is the info:
    ThinkNode M5 Meshtastic (LoRa) Signal Transceiver |ESP32-S3 | 1.54” Screen | GPS Function
    SKU: ILM13205D1
    Order #262321
    Do you need anything else?
  • @deadbeef said:
    Hi Jennie
    Flash log:
    esptool.js
    Connecting...
    Crystal is 40MHz
    Uploading stub...
    Running stub...
    Stub running...
    Leaving...
    then bootlog:
    Build:Mar 27 2021
    Saved PC:0x40049b21
    Dear Customer,
    Sorry for the late reply.
    We've tested it and it works fine. Was your device functioning correctly before these 2 firmwares was flashed? This log shows the device is constantly restarting. Please try flashing the firmware again.
    Thanks! Best regards,
