Minecraft
Hello, I am thinking of ordering the new crowPie2 laptop. I have some questions. Minecraft. How exactly can someone craft buildings? Can I use this later on, in the actual Minecraft? (as a seed or any other way) Does it connect to Minecraft or is it only on the elecrow laptop? Can you play Minecraft or has a limited function?
  • The answer to your question is as follows.
    1. Those craft building entities have RFID tags added inside them and need to be paired with Crowpi2's RFID identification module to function, so they won't work on other actual Minecraft. We haven't tried to find out if it's possible to save seeds or anything like that, so maybe you can give it a try!
    2. Generally, if you have the same version number, you can connect, but you will need to find out how to do so.
  • edited October 2025
    I’ve tried something similar before — it’s fun but not the same as full Minecraft. The crowPie2 tools feel more like creative simulators than actual world seeds. It reminds me of nullsbrawlapkz.com.tr/nulls-brawl-ios where you can test custom builds before jumping into the main game. Have you checked how it handles exports?
  • From what I know, crowPie2 lets you build locally but doesn’t sync straight to Minecraft servers. Still, it’s a cool way to experiment. I’ve seen setups like nullsbrawl.net.tr that let players test mechanics before going live. Do you think crowPie2 might ever add direct world upload support?
  • Hello, I’m considering ordering the new CrowPie2 laptop and have some questions about Minecraft. Can I craft buildings on it and later use them in the official game—like as a seed or export? Does it fully run Minecraft, or is it limited to the CrowPie2 environment? For guidance on Minecraft APKs and versions, you can check
  • If you’re mainly thinking about Minecraft and gaming, Apple devices like iMacs and MacBooks are a solid option. On macOS you can run the official Minecraft version, build worlds normally, save them, and even use them later or move them between devices using your account. That’s different from custom or limited systems, which often don’t let you reuse builds outside their own environment.
    On the mobile side, iPhones are great for gaming too, especially for fast-paced multiplayer games. For example, if you enjoy competitive gameplay alongside Minecraft, you can also play Null’s Brawl for iOS via nullsbrawlg which runs smoothly on iPhone and fits well into the Apple ecosystem. Overall, Apple devices give you more flexibility compared to restricted or custom laptop setups.
  • edited 9:14PM
    The CrowPi 2 doesn’t directly connect to Minecraft or generate buildings that you can export as seeds or files into the actual game, it’s mainly a learning laptop for programming and electronics. You can install and play Minecraft (usually the Java Edition or Minecraft Pi) on it like a normal computer, depending on the OS you use, but any buildings you create in educational tools or coding projects on the device won’t automatically transfer to your real Minecraft worlds.
