Dear mshettha,
Sorry for the late reply.
Sorry, this device doesn't support fan speed control. Using node-red to control screen brightness is theoretically possible (you'll need to test it to be sure), and we don't have a tutorial yet, so you'll need to figure it out yourself.
Sorry for the inconvenience .
Best regards,
Dear mshettha,
The instructions are all here. To locate this folder , you can use this command:
sudo find /usr -name "scripts"
Dear Jennie,
Many thanks for sharing, I found the "scripts" folder. I have have tried to adjust screen brightness by using command "python brightness.py 100 screen". But the screen brightness is not change. Please give me some example in using this command.
Please also give me the example command to control CPU fan speed as well.
Hi Jennie,
Is there any update on this topic?
I'm still waiting your reply, this is my only one hope. If you and your team can't give advice, no one can't do that.
Thank you,
Shettha
@mshettha said:
Hi Jennie,
Thank you,
Shettha
Dear Mshettha ,
We've received your messages. Our technical support team is currently looking into the issue in your messages. Please be patient, and we will get back to you as soon as possible.
Dear Mshettha ,
Sorry for the late reply .
I'm very sorry. The fan of the pi terminal cannot be set. The programs are all in that folder. You'll have to figure it out by yourself.
Thanks!
Warm regards,
Dear mshettha,
Thanks! Have a nice day!
Dear mshettha,
Best regards,
Hi Jennie,
Apart from node-red. Can I do fan speed control and screen brightness by command line?
Thank you,
Dear mshettha,
Thanks! Have a good day!
Dear mshettha,
Dear Jennie,
Hi Jennie,
Thank you,
Shettha
Dear Mshettha ,
Thanks!
Warm regards,
Dear Mshettha ,
Thanks!
Warm regards,
