Pi Terminal 7 inch: How to control CPU fan speed and screen brightness
Hello,
Regardsin Pi Termianl 7 inch. I'd like to know how to control CPU fan speed and screen brightness using Node-RED dashboard, please advise.
  • Dear mshettha,
    Thanks! Have a nice day!
  • edited August 8
    Dear mshettha,
    Sorry for the late reply.
    Sorry, this device doesn't support fan speed control. Using node-red to control screen brightness is theoretically possible (you'll need to test it to be sure), and we don't have a tutorial yet, so you'll need to figure it out yourself.
    Sorry for the inconvenience .
    Best regards,
  • Hi Jennie,
    Apart from node-red. Can I do fan speed control and screen brightness by command line?
    Thank you,
  • @mshettha said:
    Hi Jennie,
    Thank you,
    Dear mshettha,
    Thanks! Have a good day!
  • Dear mshettha,
    The instructions are all here. To locate this folder , you can use this command:
    sudo find /usr -name "scripts"
  • Dear Jennie,
    Many thanks for sharing, I found the "scripts" folder. I have have tried to adjust screen brightness by using command "python brightness.py 100 screen". But the screen brightness is not change. Please give me some example in using this command.
    Please also give me the example command to control CPU fan speed as well.
  • Hi Jennie,
    Is there any update on this topic?
    I'm still waiting your reply, this is my only one hope. If you and your team can't give advice, no one can't do that.
    Thank you,
    Shettha
  • @mshettha said:
    Hi Jennie,
    Thank you,
    Shettha
    Dear Mshettha ,
    We've received your messages. Our technical support team is currently looking into the issue in your messages. Please be patient, and we will get back to you as soon as possible.
    Thanks!
    Warm regards,
