CrowPi L replacement battery
And idea where I can get a replacement battery for the CrowPi L or does anyone have a wiring diagram for the laptop
Hi deathcat99,
Thank you for reaching out.
Our technical support team is currently looking into your issue. Please be patient, and we will get back to you as soon as possible.
Best regards,
@Jennie Thank you, please let me know what my options are
Hi deathcat99,
You are welcome. Thank you for your patience in solving the issue.
I am sorry that we don’t sell the battery separately. You may try to find a replacement through other channels.
As for the wiring diagram of the laptop, I’ll need to check with our team. Please kindly wait for my update.
Best regards,
Hi deathcat99,
You can buy a battery yourself and connect it according to this wiring diagram, where the left two are positive and the right two are negative, and the middle one is useless.
Thank you so much, just for my own understanding what does the board that's on the OEM battery do(the battery has two 3.7v cells and some sort of balance/battery management board?) I just wanted to confirm, because based on what I am seeing I just need a 7.4 Battey and add two positive and negative leads wired to the plug on the laptop.
Hi deathcat99,
Yes, you just need to connect a 7.4V battery to the laptop.
