Joystick re-upload the factory and connect to the CrowBot/ not working
Dear All
Hello
I hope this email finds you well.
I'm trying to re-upload the factory default code to the joystick and im using
"Factory source code/ Handle_remote_control_program".
Also, Im sure the board is correctly chosen:
But every time im facing the below error:
C:\Users\Student\Desktop\Factory source code\Handle_remote_control_program\Handle_remote_control_program.ino: In function 'void setup()':
C:\Users\Student\Desktop\Factory source code\Handle_remote_control_program\Handle_remote_control_program.ino:384:3: error: 'ledcSetup' was not declared in this scope
384 | ledcSetup(9, 5000, 8);
C:\Users\Student\Desktop\Factory source code\Handle_remote_control_program\Handle_remote_control_program.ino:385:3: error: 'ledcAttachPin' was not declared in this scope; did you mean 'ledcAttach'?
385 | ledcAttachPin(6, 9);
| ledcAttach
C:\Users\Student\Desktop\Factory source code\Handle_remote_control_program\Handle_remote_control_program.ino: In function 'void loop()':
C:\Users\Student\Desktop\Factory source code\Handle_remote_control_program\Handle_remote_control_program.ino:568:53: error: no match for 'operator=' (operand types are 'std::string' {aka 'std::__cxx11::basic_string<char>'} and 'String')
568 | Distance = pCharacteristic2->getValue();
In file included from C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/string:54,
from C:\Users\Student\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\BLE\src/BLEDevice.h:18,
from C:\Users\Student\Desktop\Factory source code\Handle_remote_control_program\Handle_remote_control_program.ino:1:
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:941:8: note: candidate: 'template<class _Tp> constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::_If_sv<_Tp, std::__cxx11::basic_string<_CharT, _Traits, _Alloc>&> std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(const _Tp&) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
941 | operator=(const _Tp& __svt)
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:941:8: note: template argument deduction/substitution failed:
In file included from C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/stl_pair.h:60,
from C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/stl_algobase.h:64,
from C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/specfun.h:43,
from C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/cmath:3898,
from C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/math.h:36,
from C:\Users\Student\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32/esp32-hal.h:30,
from C:\Users\Student\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\cores\esp32/Arduino.h:45,
from C:\Users\Student\AppData\Local\arduino\sketches\86A097FCBA49AE823DDA51A1D1BF68FE\sketch\Handle_remote_control_program.ino.cpp:1:
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/type_traits: In substitution of 'template<bool _Cond, class _Tp> using std::enable_if_t = typename std::enable_if::type [with bool _Cond = false; _Tp = std::__cxx11::basic_string<char>&]':
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:149:8: required by substitution of 'template<class _CharT, class _Traits, class _Alloc> template<class _Tp, class _Res> using std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::_If_sv = std::enable_if_t<((bool)std::__and_<std::is_convertible<const _Tp&, std::basic_string_view<_CharT, _Traits> >, std::__not_<std::is_convertible<const _Tp*, const std::__cxx11::basic_string<_CharT, _Traits, _Alloc>*> >, std::__not_<std::is_convertible<const _Tp&, const _CharT*> > >::value), _Res> [with _Tp = String; _Res = std::__cxx11::basic_string<char>&; _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
149 | using _If_sv = enable_if_t<
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:941:8: required by substitution of 'template<class _Tp> constexpr std::__cxx11::basic_string<char>::_If_sv<_Tp, std::__cxx11::basic_string<char>&> std::__cxx11::basic_string<char>::operator=(const _Tp&) [with _Tp = String]'
C:\Users\Student\Desktop\Factory source code\Handle_remote_control_program\Handle_remote_control_program.ino:568:53: required from here
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/type_traits:2696:11: error: no type named 'type' in 'struct std::enable_if<false, std::__cxx11::basic_string<char>&>'
2696 | using enable_if_t = typename enable_if<_Cond, _Tp>::type;
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:817:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(const std::__cxx11::basic_string<_CharT, _Traits, _Alloc>&) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
817 | operator=(const basic_string& __str)
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:817:37: note: no known conversion for argument 1 from 'String' to 'const std::__cxx11::basic_string<char>&'
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:828:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(const _CharT*) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
828 | operator=(const _CharT* __s)
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:828:31: note: no known conversion for argument 1 from 'String' to 'const char*'
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:840:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(_CharT) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
840 | operator=(_CharT __c)
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:840:24: note: no known conversion for argument 1 from 'String' to 'char'
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:858:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(std::__cxx11::basic_string<_CharT, _Traits, _Alloc>&&) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
858 | operator=(basic_string&& __str)
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:858:32: note: no known conversion for argument 1 from 'String' to 'std::__cxx11::basic_string<char>&&'
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:926:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(std::initializer_list<_Tp>) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
926 | operator=(initializer_list<_CharT> __l)
C:/Users/Student/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2411/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:926:42: note: no known conversion for argument 1 from 'String' to 'std::initializer_list<char>'
C:\Users\Student\Desktop\Factory source code\Handle_remote_control_program\Handle_remote_control_program.ino:569:52: error: no match for 'operator=' (operand types are 'std::string' {aka 'std::__cxx11::basic_string<char>'} and 'String')
569 | Warning = pCharacteristic3->getValue();
Multiple libraries were found for "Ticker.h"
Used: C:\Users\Student\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\Ticker
Not used: C:\Users\Student\Documents\Arduino\libraries\Ticker
exit status 1
Compilation error: 'ledcSetup' was not declared in this scope
Also, I have installed:
{4F6E798E-4DE9-4FF3-9CF1-F0C59B245A46}.png {9602BF1F-4877-423A-9A9F-7A3D33676C8B}.png
Dear kamran1,
Regarding your question, we have contacted you by email, please check your email.
Thanks.
