LM2596S - Config process has no effect
Hello,
Wondering if anyone has experience with this DC-DC module?
The instructions say to hold the button >4 seconds after power on to configure/adjust the input and output voltages (I need to output 5v from a 12v input). However nothing happens doing that. The display just switches off and I cannot enter any information.
Has anyone else had this problem?
Best Regards,
D
  • Hello,
    May I kindly ask did you connect the power supply input?
  • Hello,
    Yes, power supply input was there. Red light came on and input voltage displayed. Able to switch to output voltage (same as input - 1v). But no ability to enter config mode to tune the input or output.
    Best Regards,
    D
  • Any more on this?
  • SunSun
    edited October 2024
    Hello D, I also tried the product page method and it really doesn't work. That method is used to calibrate the output voltage value though, it doesn't correct your output voltage. You need to adjust the resistor value by rotating the copper coloured notch on the adjustable resistor. The change in resistance value will change the voltage output. Hopes this help you.
    Please also check to see if your mailbox is not receiving mail properly. Have a good weekend..
  • edited October 2024
    Hello Sun,
    Yes, I understood that you are supposed to be able to change the output by tuning the pot, however nothing was being changed by altering that, turning in any direction, as my multimeter confirmed.
    I believe this unit was defective when I received it, as now the device is simply showing the red light, with no display of the input voltage, and will not change to the green light or show the output voltage, or anything, on the display.
    Very disappointing.
    Regards,
  • @dSquared1801 said:
    Hello,
    Best Regards,
    D
    Hi there,
    I haven't encountered this specific issue with the DC-DC module you mentioned. However, it's worth double-checking the module's documentation or reaching out to the manufacturer for specific guidance.
    Here are some general troubleshooting tips:
    Power Supply: Ensure the 12V input power supply is stable and sufficient.
    Button Press: Experiment with different button press durations and release timings.
    Display Check: Verify if the display is working correctly and if there are any visible indicators during the configuration process.
    Module Reset: Try resetting the module by disconnecting the power supply for a few seconds.
    If these steps don't resolve the issue, consider seeking help from online forums or communities dedicated to electronics and DIY projects. They might have specific solutions or workarounds for your particular module.
    In the meantime, you might want to explore other options for converting 12V to 5V, such as using a voltage regulator IC or a pre-built DC-DC converter module.
    Let me know if you have any further questions.
    Hello,
    Best Regards,
    D
    Hello, I’ve encountered a similar issue before. It could be a problem with the button or the wiring. Try ensuring that the module is properly connected, and ensure you're holding the button for a full 4 seconds with a stable 12V input. If it still doesn’t work, check the manual or consider resetting the module.
  • It sounds like you're encountering an issue with the LM2596S DC-DC module where the configuration process isn't working as expected. A couple of things could be going wrong:
    Button Hold Time: Ensure you're holding the button down for the correct amount of time (typically >4 seconds). Sometimes, it can be a bit tricky to get the timing right.
    Voltage Levels: Make sure that the input voltage is within the supported range for the module. If the module isn’t receiving a stable input (like 12V), the configuration might not work properly.
    Connection Issues: Double-check the wiring, especially the ground connection. Sometimes, improper grounding can cause the module to not respond correctly.
    This situation is similar to troubleshooting in games like Worms Zone Mod APK, where minor setup or timing errors can prevent the game from running as expected. Properly setting up the input and connection should resolve the issue.
