ESP 43 inch Display slow
Hi I have a 43 Display. The program work correctly but very slow. Sometimes it take 6 seconds to output a command. I send commands to 3 esp32's via ESP-now.
What did I do wrong. I spent a lot of time trying to speed it up by removing functions but only make it worse. Can you please suggest a fix please.
Hello, here are some optimization suggestions:
Modification suggestion 1:
Replace the delay function with the FreeRTOS time function.
Modification suggestion 2:
Reduce the frequency of reading the DHT22 sensor to avoid reading it in every loop.
Hope these can help you.
Hi, I urgently needs help. I uploaded the above attach code and it failed to upload. It give me loads of errors, errors I haven't seen before. I don't know if something changed in one of the libraries as it always loaded up before last Friday. I replaced all libraries but it seems to make it worse. Please help.
I'm using LVGL 8.3.11 and a 5inch touch display SKU-DIS07050H
Hello @jdebruyn ,
Are you still need help for ESP 4.3 inch Display slow,
or need help for 5 inch display problem?
Could you provide more detailed information about the 5-inch display?
Why would you upload the above code from a 5 inch screen? How is it now?
If possible,please send me the code and error message and the configuration for the 5-inch compilation error.
I was in the proses to do the above fix and could not get the code to upload due to the many errors. I misprinted I am using a 5inch not 4.3inch. The following are the last 3 errors, there are many more: E:\New_Project_V1\Trans_RGB_Stepper_StringAdj_V5\Transmitter_18.8.24_V5\Steel_V4_Trans\Steel_V4_Trans.ino:159:10: error: 'lv_indev_drv_t' does not name a type; did you mean 'lv_indev_data_t'?
159 | static lv_indev_drv_t indev_drv;
| lv_indev_data_t
E:\New_Project_V1\Trans_RGB_Stepper_StringAdj_V5\Transmitter_18.8.24_V5\Steel_V4_Trans\Steel_V4_Trans.ino:160:22: error: 'indev_drv' was not declared in this scope
160 | lv_indev_drv_init(&indev_drv);
E:\New_Project_V1\Trans_RGB_Stepper_StringAdj_V5\Transmitter_18.8.24_V5\Steel_V4_Trans\Steel_V4_Trans.ino:160:3: error: 'lv_indev_drv_init' was not declared in this scope; did you mean 'lv_fs_drv_init'?
| lv_fs_drv_init
E:\New_Project_V1\Trans_RGB_Stepper_StringAdj_V5\Transmitter_18.8.24_V5\Steel_V4_Trans\Steel_V4_Trans.ino:162:23: error: 'my_touchpad_read' was not declared in this scope
162 | indev_drv.read_cb = my_touchpad_read;
E:\New_Project_V1\Trans_RGB_Stepper_StringAdj_V5\Transmitter_18.8.24_V5\Steel_V4_Trans\Steel_V4_Trans.ino:163:3: error: 'lv_indev_drv_register' was not declared in this scope; did you mean 'lv_fs_drv_register'?
163 | lv_indev_drv_register(&indev_drv);
| lv_fs_drv_register
exit status 1
Compilation error: 'LV_IMGBTN_STATE_RELEASED' undeclared (first use in this function); did you mean 'LV_IMAGEBUTTON_STATE_RELEASED'?
Code for the above.
Hello @jdebruyn ,
I understand you're facing issues with slow performance in your ESP32 program that uses ESP-NOW to send commands to three devices. I'll review your code and suggest potential fixes.
Here are a few observations and suggestions based on your code:
1. ESP-NOW Send Latency
cpp uint8_t *broadcastAddresses[] = {broadcastAddress, broadcastAddress2, broadcastAddress3}; for (int i = 0; i < 3; i++) { esp_now_send(broadcastAddresses[i], (uint8_t *)&myData1, sizeof(myData1)); }
esp_now_send
function isn't blocking due to retries or waiting for acknowledgment. Check ifesp_now_register_send_cb
reveals any failures and try reducing data size if needed.2. UI Updates in
loop()
lv_label_set_text
andlv_snprintf
for each slider might be slowing things down. Consider updating the UI only when slider values change:cpp static int prev_Slider_LL = -1; // Example for Slider_LL int Slider_LL = (int)lv_slider_get_value(ui_Slider_LL); if (Slider_LL != prev_Slider_LL) { lv_snprintf(buf, sizeof(buf), "LL: %d", Slider_LL); lv_label_set_text(ui_A5, buf); prev_Slider_LL = Slider_LL; }
3. Sensor Reading Delay
delay(100)
for the DHT22 sensor at the end ofloop()
could slow down the entire process. Instead, use a non-blocking approach:cpp unsigned long lastDHTRead = 0; if (millis() - lastDHTRead > 2000) { // Read every 2 seconds lastDHTRead = millis(); float temp = dht.readTemperature(); float humid = dht.readHumidity(); // Handle sensor data }
4. LVGL Rendering Performance
screenWidth * screenHeight / 8
to higher values if memory permits.lv_task_handler()
instead oflv_timer_handler()
if rendering is taking too long.5. Optimize Wi-Fi/ESP-NOW
peerInfo.encrypt = false
).6. Parallelism
Would you like me to suggest more FreeRTOS-based solutions, or do you need help implementing any of the above?
Thanks for the feedback, however at this moment I cannot upload the code to my ESP32 as there is too many errors. I was able to fix and upload before but as of Last Friday it keeps on failing to upload. Would you mind to please check why. Could it be the display or code, I am out of ideas. Thanks for your time.
Errors I get: error: 'lv_indev_drv_init' was not declared in this scope; did you mean 'lv_fs_drv_init'?
161 | indev_drv.type = LV_INDEV_TYPE_POINTER;
| lv_fs_drv_init
164:3: error: 'lv_indev_drv_register' was not declared in this scope; did you mean 'lv_fs_drv_register'?
164 |
| lv_fs_drv_register
exit status 1
Compilation error: variable or field 'my_disp_flush' declared void
I have checked this error message of yours and the code is normal, it is the same as in our example, it is normal. Did you change the library?
I didn't change the Library, how will I manage the errors as it stop the uploading?
