Where can I find /dev/sda?
I have entered a SD card in the SD card slot for additionnal storage.
Where can I find this SD card? If I try to mount it in a terminal it says that it is already mounted but I don'f find where?
Hello, You can find the SD card in the location indicated by the image. Please refer to the image.
I think it should be /dev/sdb since external devices on linux for me are always mounted like it , don't know about your setup but I think utilities like gparted will do the trick for you.
The microSD slot on the Pi is assign as mmcblk0. To locate the mount point on your system, open a terminal and use the command lsblk to display its mount point.
Below is an example on my system:
@pearl ,
really appreciate it ,Thanks bro.
Thanks @pearl,
you are a saviour to me. Thanks my friend.
Thanks @Pearl and also to the op.
These things always confuse me. I really appreciate the help.
