'Lesson 13 ESPHome' not working with CrowPanel 7.0"
2»
  • edited November 1
    Hello,
    After a while I stumbled across this article here. I ordered the 7” display at the end of October and received it yesterday. It is version 3.
    Unfortunately, the error is probably also occurring with it.
    The screen only shows a few pixel lines at the bottom. it is a pity that it does not work, but also that it is not mentioned before the purchase that it probably does not work with ESPHome and the 7” display
    I have now written to the manufacturer.
  • @enjoydevelopment said:
    Hello,
  • Hello @Winny
    Yes, it starts in grey and then turn slowly to black .But black Screen only....
    The example für Touch works (touchscreen: platform: gt911) and touchinfos available in the log
  • @Elecrow : what does it mean ? Will there be an new Version of CrowPanel 7-inch HMI that works with ESPHOME
    Your Reply on July 22 2024
    "We're sorry the ESP32 clock is too slow, the 7-inch HMI driver IC cannot recognize the RGB signal. So the 7-inch display doesn't support ESPHOME. To solve this problem, we change the LCD panel. But the new version of the CrowPanel 7-inch HMI has not yet entered production."
  • Does the example run on someone's 7” display?
    a gray screen starts on mine which then turns black. But there are no widgets to be seen
    @Winny said:
    Hello guys,
    Here's the ESPHome demo for the CrowPanel 7-inch ESP32 display: https://www.elecrow.com/wiki/CrowPanel_ESP2_7.0-inch_with_ESPHome.html
  • Hello @enjoydevelopment ,
    May I kindly ask did you placed the UI files on the server?
    What's more, you need to modify the wifi
