Battery charging circuit on 7"
Is there any kind of information on the battery charging circuit on the 7" HMI?
How large a lithium battery can I connect to it?
What is the charging rate?
Is there any way to know if the battery is fully charged?
Thanks.
  • edited February 17
    1.Battery capacity is not limited
    2.Charging time = battery capacity (for example 1000MAH)/500MA*1.2=2.4 hours
    3.Use a multimeter to measure the positive and negative voltage of the battery when it is fully charged at 4.2V.
  • Hi there. From what I could see in the product spec page both the HMI 5" and 7" circuitry are the same, and I could not see it had an integrated charging circuitry for the LiPO batteries, as this thread would suggest. Can you pls confirm if that's the case?
  • edited October 25
    Hello, please refer to the schematic diagram.
    5.0inch
    7.0inch
    Both have lithium battery management chips.
