Where can I find /dev/sda?
I have entered a SD card in the SD card slot for additionnal storage.
Where can I find this SD card? If I try to mount it in a terminal it says that it is already mounted but I don'f find where?
  • edited August 2023
    Hello, You can find the SD card in the location indicated by the image. Please refer to the image.
  • I think it should be /dev/sdb since external devices on linux for me are always mounted like it , don't know about your setup but I think utilities like gparted will do the trick for you.
  • The microSD slot on the Pi is assign as mmcblk0. To locate the mount point on your system, open a terminal and use the command lsblk to display its mount point.
    Below is an example on my system:
    pi@rpi:~ $ lsblk
    NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
    sda           8:0    0 465.8G  0 disk
    ├─sda1        8:1    0   256M  0 part /boot
    └─sda2        8:2    0 465.5G  0 part /
    mmcblk0     179:0    0  29.7G  0 disk
    ├─mmcblk0p1 179:1    0   256M  0 part /media/pi/boot
    └─mmcblk0p2 179:2    0  29.5G  0 part /media/pi/rootfs
  • @pearl ,
    really appreciate it ,Thanks bro.
  • Thanks @pearl,
    you are a saviour to me. Thanks my friend.
  • Thanks @Pearl and also to the op.
    These things always confuse me. I really appreciate the help.
