Display Response difference
I am using 3.5 and 5 inch displays.
1. CrowPanel –ESP32 Terminal with 3.5 inch parallel 480x320 TFT capacitive touch RGB display(RGB by chip ILI9488)
2. CrowPanel 5.0"-HMI ESP32 Display 800x480 RGB TFT LCD Touch Screen Compatible with Arduino/LVGL/ PlatformIO/Micropython
I believe both are having the RGB interface but i am seeing faster display response in the 3.5 inch than the 5 inch display. Is there any difference in the interfaces?
  • Terminal RGB resolution is small, the memory is larger. So the Terminal reaction is going to be faster than the 5inch display.
  • ok. So, both display's interface is same, only the memory and resolution are the causes for this response timing difference? But I observed a clock frequency difference in the hal folder of the demo codes.
  • Here the frquency difference in the code
    In the 5" inch display main program(demo code) cfg.freq_write = 15000000;
    In the 3.5" inch display main program(demo code) cfg.freq_write = 80000000;
    I tried to set the cfg.write value in the 5" inch display "cfg.write = 80000000" value as same as 3.5" inch display by expecting the faster display response. but display is not up as expected.
    why this frequency differences?
  • @Winny @Sun
    Could you please explain these freq_write differences which I mentioned in the previous comments?
    Thanks in advance
  • edited October 31
    Hi @Anand ,
    Due to the hardware limitation of the 5-inch HMI screen, it works more stably at a frequency between 10-20 MHz. Exceeding this range may cause image distortion or display errors. If your hardware version is 3.0, you can try to increase cfg.freq_write, but not too high.
