Crow Panel 7.0in Brightness spec
Hi
I am interested in the LVGL capable Esp32 Crowpanel 7.0", and I was wondering, what is the max brightness of this display? I'm using this in a potential bright environment, and want to know the candela(nits) spec of the display
Hello @Nasiraod ,
The maximum screen brightness is 240Cd/cm2, we recommend use it indoor.
I got it, thank you very much
Are there any plans to make something brighter under the same platform?
I am trying to use this in a product that would sit inside a car, so I would need it to be visible in the sun. If it had been brighter, it would be perfect for my application
Brightness around 800Cd/cm2 would be ideal
Hello @Nasiraod
Thank you for your feedback. In the future, we will launch a new version of ESP32 HMI, using a wider viewing angle and higher brightness screen. Please stay tuned!
Great, would be essentially the same platform? Would I be able to buy current one for prototyping? I would like to directly port the firmware to the new screen
Hello @Nasiraod ,
The new version of ESP32 HMI is expected to use a more powerful ESP32 chip
Great, thank you
Any idea when will the display with the higher brightness be available?
