How should solve the errors when using the LR1302 Gateway Module+HAT
Error 1
Note: chip version is 0x00 (v0.0)
ERROR: Failed to set SX1250_0 in STANDBY_RC mode
ERROR: failed to setup radio 0
ERROR: failed to start the gateway
Error 2
ERROR: [main] failed to start the concentrator
If you encounter the similar error, make sure you're using buster first. They are not currently supported for use with bullseye and bookworm.
If you still have the same error using the buster version, it may be that the configuration is not completely correct. Try the configured image (https://drive.google.com/drive/folders/1LL42h4sYU6f8MrvipY9GQXjcZutR_NGr?usp=sharing) provided by Elecrow.
