Touchscreen on CrowPanel 7inch v3.0 not working
2»
  • Winny,
    how do i send you the code? I have not recieved an email from you yet.
  • @RCRoeder said:
    Winny,
    Hi,
    You can try modify the following sentence in the sample code I sent.
    And please remember to check the psram setting is correct.
    If it still not working, please contact us at techsupport@elecrow.com
  • one thing i have noticed is the gfx_conf.h file references lgfx::Touch_GT911 _touch_instance, but if we are now using PCA9557 is this a conflict? Still have no touch. I was told i should send my code to you, and i would be contacted. No contact so i am postingthe code here.
    // esp32 by Expressif Systems 2.9.15
    // Arduino ESP32 Boards by Arduino 20.0.13
    // LovyanGFX by Lovyan03 1.1.12
    // lvgl by kisvegabor 8.3.11
    // PCA9557
    // PSRAM; opi psram
    // Partition Scheme: Huge App
    include <Wire.h>
    include <SPI.h>
    include <PCA9557.h>
    include <lvgl.h>
    #include "ui.h"
    /**************************LVGL and UI END************************/
    Config the display panel and touch panel in gfx_conf.h
    include "gfx_conf.h"
    static lv_color_t disp_draw_buf1[screenWidth * screenHeight / 10];
    static lv_color_t disp_draw_buf2[screenWidth * screenHeight / 10];
    PCA9557 Out; //for touch timing init
    /* Display flushing */
    void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
    uint32_t w = ( area->x2 - area->x1 + 1 );
    uint32_t h = ( area->y2 - area->y1 + 1 );
    tft.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full);
    lv_disp_flush_ready( disp );
    void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
    uint16_t touchX, touchY;
    bool touched = tft.getTouch( &touchX, &touchY);
    if( !touched )
    else
      /*Set the coordinates*/
      data->point.x = touchX;
      data->point.y = touchY;
      Serial.print( "Data x " );
      Serial.println( touchX );
      Serial.print( "Data y " );
      Serial.println( touchY );
    Serial.println("LVGL Widgets Demo");
    //GPIO init
    if defined (CrowPanel_50) || defined (CrowPanel_70)
    pinMode(38, OUTPUT);
    digitalWrite(38, LOW);
    pinMode(17, OUTPUT);
    digitalWrite(17, LOW);
    pinMode(18, OUTPUT);
    digitalWrite(18, LOW);
    pinMode(42, OUTPUT);
    digitalWrite(42, LOW);
    //touch timing init
    Wire.begin(19, 20);
    Out.reset();
    Out.setMode(IO_OUTPUT);
    Out.setState(IO0, IO_LOW);
    Out.setState(IO1, IO_LOW);
    delay(20);
    Out.setState(IO0, IO_HIGH);
    delay(100);
    Out.setMode(IO1, IO_INPUT);
    elif defined (CrowPanel_43)
    pinMode(20, OUTPUT);
    digitalWrite(20, LOW);
    pinMode(19, OUTPUT);
    digitalWrite(19, LOW);
    pinMode(35, OUTPUT);
    digitalWrite(35, LOW);
    pinMode(0, OUTPUT);//TOUCH-CS
    endif
    //Display Prepare
    tft.begin();
    tft.fillScreen(TFT_BLACK);
    tft.setTextSize(2);
    delay(200);
    lv_init();
    delay(100);
    lv_disp_draw_buf_init(&draw_buf, disp_draw_buf1, disp_draw_buf2, screenWidth * screenHeight/10);
    /* Initialize the display /
    lv_disp_drv_init(&disp_drv);
    Change the following line to your display resolution */
    disp_drv.full_refresh = 1;
    /* Initialize the (dummy) input device driver */
    ui_init();
    lv_timer_handler();
    delay(5);
