Bluetooth on the 5 inch screen - function not supported?
Hello, I just tried to follow the Course guides, with the idea I just wanted to test bluetooth on the 5inch panel version.
Based on what I can see, It doesn't work? Am I missing something?
Simplified, the code to try and connect via bluetooth classic (master to slave) would be:
#include "BluetoothSerial.h"
BluetoothSerial SerialBT;
SerialBT.begin(myName, true); // Start Bluetooth serial
SerialBT.setPin(pin); // Set the pairing code
With the last line of code, I get this error
no matching function for call to 'BluetoothSerial::setPin(const char*&)'
It's a v3 panel if that helps.
What step am I missing?
I thought I'd try an isolated piece of code using solely bluetooth as well, but I think I'm missing something there too - the code won't compile for the board using this.
The error I get here is "Error compiling for board ESP32S3 Dev Module."
Hello @SuperRoach
The chip of the 5-inch HMI is ESP32 S3, which doesn't support Bluetooth.
And for the error message, please check if the setting is correct(please refer to https://www.elecrow.com/wiki/ESP32_Display_5.0-inch_HMI_Arduino_Tutorial.html#upload-the-code )
