The Lora Basic Gateway Module Build Errors
I saw and checked Elecrow's official Wiki.
https://www.elecrow.com/wiki/lora-basic-gateway-module.html
But, I encountered problems when I upload the programs to module.
I attached error messages in mu error message from Arduino IDE.
Can anyone help me?
Please give me tips!
In file included from /Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:83:
/Users/himitu23/Documents/Arduino/libraries/WiFiManager-development/WiFiManager.h:458:41: error: 'system_event_info_t' has not been declared
458 | void WiFiEvent(WiFiEvent_t event, system_event_info_t info);
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:153:1: error: reference to 'byte' is ambiguous
153 | byte currentMode = 0x81;
In file included from /Users/himitu23/Library/Arduino15/packages/esp32/tools/esp-x32/2302/xtensa-esp32-elf/include/c++/12.2.0/cmath:42,
from /Users/himitu23/Library/Arduino15/packages/esp32/tools/esp-x32/2302/xtensa-esp32-elf/include/c++/12.2.0/math.h:36,
from /Users/himitu23/Library/Arduino15/packages/esp32/hardware/esp32/3.0.3/cores/esp32/esp32-hal.h:30,
from /Users/himitu23/Library/Arduino15/packages/esp32/hardware/esp32/3.0.3/cores/esp32/Arduino.h:36,
from /private/var/folders/wj/5lmr_hhs7k9dq5sl5v2mg_w00000gp/T/arduino/sketches/E6BCFF1A13E5C8168F513B99BD9D1F77/sketch/ESP-sc-gway-end.ino.cpp:1:
/Users/himitu23/Library/Arduino15/packages/esp32/tools/esp-x32/2302/xtensa-esp32-elf/include/c++/12.2.0/bits/cpp_type_traits.h:406:30: note: candidates are: 'enum class std::byte'
406 | enum class byte : unsigned char;
/Users/himitu23/Library/Arduino15/packages/esp32/hardware/esp32/3.0.3/cores/esp32/Arduino.h:149:17: note: 'typedef uint8_t byte'
149 | typedef uint8_t byte;
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:719:6: error: variable or field 'hexCharacterStringToBytes' declared void
719 | void hexCharacterStringToBytes(byte *byteArray, const char *hexString)
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:719:32: error: reference to 'byte' is ambiguous
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:719:38: error: 'byteArray' was not declared in this scope
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:719:49: error: expected primary-expression before 'const'
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:765:1: error: reference to 'byte' is ambiguous
765 | byte nibble(char c)
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino: In function 'void setup()':
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:187:25: error: invalid conversion from 'int' to 'eth_phy_type_t' [-fpermissive]
187 | #define ETH_PHY_ADDR 0
| int
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:924:15: note: in expansion of macro 'ETH_PHY_ADDR'
924 | ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER, ETH_PHY_MDC, ETH_PHY_MDIO, ETH_PHY_TYPE, ETH_CLK_MODE);
In file included from /Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:186:
/Users/himitu23/Library/Arduino15/packages/esp32/hardware/esp32/3.0.3/libraries/Ethernet/src/ETH.h:126:29: note: initializing argument 1 of 'bool ETHClass::begin(eth_phy_type_t, int32_t, int, int, int, eth_clock_mode_t)'
126 | bool begin(eth_phy_type_t type, int32_t phy_addr, int mdc, int mdio, int power, eth_clock_mode_t clk_mode);
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:982:7: error: 'hexCharacterStringToBytes' was not declared in this scope
982 | hexCharacterStringToBytes(MAC_array, gatewayid.c_str());
/Users/himitu23/Downloads/ESP-sc-gway-end/ESP-sc-gway-end.ino:1085:7: error: 'hexCharacterStringToBytes' was not declared in this scope
1085 | hexCharacterStringToBytes(MAC_array, gatewayid.c_str());
/Users/himitu23/Downloads/ESP-sc-gway-end/_WiFi.ino: In function 'IPAddress resolveHost(String, int)':
/Users/himitu23/Downloads/ESP-sc-gway-end/_WiFi.ino:328:10: error: reference to 'byte' is ambiguous
328 | for (byte i = 0; i < maxTry; i++) { // Try 5 times MDNS
/Users/himitu23/Downloads/ESP-sc-gway-end/_WiFi.ino:328:22: error: 'i' was not declared in this scope
/Users/himitu23/Downloads/ESP-sc-gway-end/_WiFi.ino:361:10: error: reference to 'byte' is ambiguous
361 | for (byte i = 0; i < maxTry; i++) {
/Users/himitu23/Downloads/ESP-sc-gway-end/_WiFi.ino:361:22: error: 'i' was not declared in this scope
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino: In function 'void stringTime(time_t, String&)':
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:319:9: error: reference to 'byte' is ambiguous
319 | byte _hour = hour(eTime);
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:320:9: error: reference to 'byte' is ambiguous
320 | byte _minute = minute(eTime);
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:321:9: error: reference to 'byte' is ambiguous
321 | byte _second = second(eTime);
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:323:9: error: reference to 'byte' is ambiguous
323 | byte _month = month(eTime);
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:324:9: error: reference to 'byte' is ambiguous
324 | byte _day = day(eTime);
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:335:13: error: '_day' was not declared in this scope; did you mean 'day'?
335 | if (_day < 10) response += "0"; response += String(_day) + "-";
| day
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:335:60: error: '_day' was not declared in this scope; did you mean 'day'?
| day
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:336:13: error: '_month' was not declared in this scope; did you mean 'month'?
336 | if (_month < 10) response += "0"; response += String(_month) + "-";
| month
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:336:62: error: '_month' was not declared in this scope; did you mean 'month'?
| month
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:339:13: error: '_hour' was not declared in this scope; did you mean 'hour'?
339 | if (_hour < 10) response += "0"; response += String(_hour) + ":";
| hour
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:339:63: error: '_hour' was not declared in this scope; did you mean 'hour'?
| hour
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:340:13: error: '_minute' was not declared in this scope; did you mean 'minute'?
340 | if (_minute < 10) response += "0"; response += String(_minute) + ":";
| minute
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:340:63: error: '_minute' was not declared in this scope; did you mean 'minute'?
| minute
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:341:13: error: '_second' was not declared in this scope; did you mean 'second'?
341 | if (_second < 10) response += "0"; response += String(_second);
| second
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:341:63: error: '_second' was not declared in this scope; did you mean 'second'?
| second
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino: In function 'int sendNtpRequest(IPAddress)':
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:351:9: error: reference to 'byte' is ambiguous
351 | byte packetBuffer[NTP_PACKET_SIZE];
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:353:16: error: 'packetBuffer' was not declared in this scope; did you mean 'setbuffer'?
353 | memset(packetBuffer, 0, NTP_PACKET_SIZE); // Zero the buffer.
| setbuffer
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino: In function 'int getNtpTime(time_t*)':
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:401:9: error: reference to 'byte' is ambiguous
401 | byte packetBuffer[NTP_PACKET_SIZE];
/Users/himitu23/Downloads/ESP-sc-gway-end/_utils.ino:402:16: error: 'packetBuffer' was not declared in this scope; did you mean 'setbuffer'?
402 | memset(packetBuffer, 0, NTP_PACKET_SIZE); // Set buffer contents to zero
| setbuffer
Multiple libraries were found for "WiFiManager.h"
Used: /Users/himitu23/Documents/Arduino/libraries/WiFiManager-development
Not used: /Users/himitu23/Documents/Arduino/libraries/WiFiManager-master
exit status 1
Compilation error: reference to 'byte' is ambiguous
