USE TFT_eSPI with Elecrow 7in RGB screen
I have written a lengthy code using TFT_eSPI library for use on a TTGO Esp32 based small screen device and want transfer this code to a Crowpanel 7.0" HMI ESP32 display panel, which I have just purchased. For the TTGO I had to edit the TFT User select file to choose the correct display setting for TTGO , can I try to load the same code and just edit the User Select file for the Crowpanel? Or is it necessary to rewrite the code using the LovyanGFX library?
