Compilieren nicht möglich siehe unten
In file included from c:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\ESP32-audioI2S-master\src/Audio.h:23,
from C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:190:
C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/include/driver/deprecated/driver/i2s.h:27:2: warning: #warning "This set of I2S APIs has been deprecated, please include 'driver/i2s_std.h', 'driver/i2s_pdm.h' or 'driver/i2s_tdm.h' instead. if you want to keep using the old APIs and ignore this warning, you can enable 'Suppress leagcy driver deprecated warning' option under 'I2S Configuration' menu in Kconfig" [-Wcpp]
27 | #warning "This set of I2S APIs has been deprecated, \
In file included from c:\users\rgogo.laptop-ptn3v7sj\documents\arduino\libraries\lvgl\src/core/lv_obj.h:140,
from c:\users\rgogo.laptop-ptn3v7sj\documents\arduino\libraries\lvgl\lvgl.h:35,
from c:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\lvgl\src/lvgl.h:17,
from C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:1:
c:\users\rgogo.laptop-ptn3v7sj\documents\arduino\libraries\lvgl\src/core/lv_obj_style.h: In function 'void lv_obj_remove_style_all(_lv_obj_t*)':
c:\users\rgogo.laptop-ptn3v7sj\documents\arduino\libraries\lvgl\src/core/lv_obj_style.h:94:48: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
94 | lv_obj_remove_style(obj, NULL, LV_PART_ANY | LV_STATE_ANY);
In file included from c:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\BLE\src/BLEClient.h:22,
from c:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\BLE\src/BLEDevice.h:19,
from C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:109:
c:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\BLE\src/BLEAdvertisedDevice.h: At global scope:
c:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\BLE\src/BLEAdvertisedDevice.h:137:31: error: 'esp_ble_gap_ext_adv_reprot_t' has not been declared
137 | virtual void onResult(esp_ble_gap_ext_adv_reprot_t report) = 0;
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino: In function 'void label_xy()':
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:553:78: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
553 | lv_obj_set_style_text_color(ui_Label, lv_color_hex(0xFF0000), LV_PART_MAIN | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:554:57: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
554 | lv_obj_set_style_text_opa(ui_Label, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:555:77: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
555 | lv_obj_set_style_text_font(ui_Label, &lv_font_montserrat_24, LV_PART_MAIN | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:564:79: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
564 | lv_obj_set_style_text_color(ui_Label3, lv_color_hex(0x00FF00), LV_PART_MAIN | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:565:58: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
565 | lv_obj_set_style_text_opa(ui_Label3, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:566:78: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
566 | lv_obj_set_style_text_font(ui_Label3, &lv_font_montserrat_24, LV_PART_MAIN | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino: In function 'void lv_example_bar()':
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:582:73: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
582 | lv_obj_set_style_bg_img_src(bar, &ui_img_bar_800_01_png, LV_PART_MAIN | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:584:78: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
584 | lv_obj_set_style_bg_img_src(bar, &ui_img_bar_800_02_png, LV_PART_INDICATOR | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:585:81: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
585 | lv_obj_set_style_outline_color(bar, lv_color_hex(0x2D8812), LV_PART_INDICATOR | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:586:60: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
586 | lv_obj_set_style_outline_opa(bar, 255, LV_PART_INDICATOR | LV_STATE_DEFAULT);
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino: In function 'void calibrateTouch(uint16_t*, uint32_t, uint32_t, uint8_t)':
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:1332:11: warning: unused variable 'values' [-Wunused-variable]
1332 | int16_t values[] = {0, 0, 0, 0, 0, 0, 0, 0};
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:1333:12: warning: unused variable 'x_tmp' [-Wunused-variable]
1333 | uint16_t x_tmp, y_tmp;
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:1333:19: warning: unused variable 'y_tmp' [-Wunused-variable]
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino: In function 'void touch_calibrate()':
C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\LvglWidgets-5.0-NOSPEAK\LvglWidgets-5.0-NOSPEAK.ino:1390:11: warning: unused variable 'calDataOK' [-Wunused-variable]
1390 | uint8_t calDataOK = 0;
Mehrere Bibliotheken wurden für "SD_MMC.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\SD_MMC
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\SD_MMC
Mehrere Bibliotheken wurden für "FFat.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\FFat
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\FFat
Mehrere Bibliotheken wurden für "BLEDevice.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\BLE
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\BLE
Mehrere Bibliotheken wurden für "WiFi.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\WiFi
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\WiFi
Mehrere Bibliotheken wurden für "Ticker.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\Ticker
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ticker
Mehrere Bibliotheken wurden für "WiFiClientSecure.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\WiFiClientSecure
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\NetworkClientSecure
Mehrere Bibliotheken wurden für "Wire.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\Wire
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Wire
Mehrere Bibliotheken wurden für "SD.h" gefunden
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\libraries\SD
Mehrere Bibliotheken wurden für "SPIFFS.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\SPIFFS
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\SPIFFS
Mehrere Bibliotheken wurden für "EEPROM.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\EEPROM
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\EEPROM
Mehrere Bibliotheken wurden für "SPI.h" gefunden
Mehrere Bibliotheken wurden für "FS.h" gefunden
Benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\Documents\Arduino\libraries\FS
Nicht benutzt: C:\Users\rgogo.LAPTOP-PTN3V7SJ\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\FS
exit status 1
Compilation error: exit status 1
Hello @RoccoGogol ,
Please check the version of the esp32 package you installed. If it is the latest version 3.0.x, we recommend that you reinstall version 2.x.x.
