Capacitive screen long press simulates mouse right button function
Test system: 2022-04-04-raspios-bullseye-armhf 32-bit (64-bit systems are not supported yet)
Software Installation
wget https://github.com/PeterCxy/evdev-right-click-emulation.git cd evdev-right-click-emulation sudo apt install build-essential libevdev2 libevdev-dev cd 'evdev-right-click-emulation' sudo cp 'out/evdev-rce' '/usr/local/bin/' sudo chmod +x '/usr/local/bin/evdev-rce'
Input the command
sudo evdev-rce
After running, you can touch and hold to implement the right-click function.
Set the pi user to be able to execute
sudo usermod -G 'input' -a pi echo 'uinput' | sudo tee -a /etc/modules sudo nano /etc/udev/rules.d/99-uinput.rules
Add the following content to the 99-uinput.rules file
KERNEL=="uinput", MODE="0660", GROUP="input"
Save and run in terminal
sudo udevadm control --reload-rules sudo udevadm trigger
then restart
sudo reboot
Run after restarting (no need for sudo at this time)
evdev-rce
Set up startup
Enter in the terminal
sudo mkdir ~/.config/autostart sudo nano ~/.config/autostart/right_click.desktop
Add the following to right_click.desktop
[Desktop Entry] Version=1.0 Type=Application Name=evdev-rce GenericName=Enable long-press-to-right-click gesture Exec=env LONG_CLICK_INTERVAL=1000 LONG_CLICK_FUZZ=200 /usr/local/bin/evdev-rce Terminal=true StartupNotify=false
If you want to modify the sensitivity, you can modify "LONG_CLICK_INTERVAL=1000"
"LONG_CLICK_FUZZ=200" these two parameters
