CrowPi2 RPi overheat ‘lightning bolt’
I get the overheat lightning bolt often, even though the CPU sensor never reads over 44C, until I remove the keyboard, then it is fine.
so thought I would add some low profile 5mm copper hearsinks, just in case.
There is no clearance to the fan holder.
Would it be OK if I (remove all electronics from case and) cut some of this plastic away to fit the heatsinks?
Looks like plenty of distance to the fan, just the housing in the way.
