LGFX issues with ESP32 3.5" terminal demo code
I have just been getting started with the 3.5 terminal (no camera) trying to run the supplied demo code. I had success and got both the B-ScreenColour and LVGL-RGB- examples compiling and downloading.
But the next day, when I tried to continue customisation of the examples - I can't get anything to compile. I can't get past:
Compilation error: 'Bus_Parallel16' in namespace 'lgfx' does not name a type
from line 26:
lgfx::Bus_Parallel16 _bus_instance;
The only think I am aware of changing is an automatic library update that happened when I started the next day, but I must admit I did not look at what library was updating, I just said yes to all.
I have re-downloaded and updated everything I can think of, and can't see what has changed. But now all the demos that use the dispaly fail.
Any clues appreciated!
Hello Barry, Have you ever tried to delete the original library and download it again?
Same issue here with the 2.8" display. If I select the ESP32-WROOM-DA module as board, I get this error. If I compile for ESP32S3 Dev Module board no errors. It seems that in libraries/LovyanGFX/src/lgfx/v1/platforms/device.hpp it take the #else in the check of the CONFIG_IDF_TARGET_xxxx defines and in the #else here is no include of a Bus_Parallel16.hpp file.
Fresh install of Arduino IDE from yesterday.
Any hints ?
Bus_Parallel16 is available in lovyanGFX for ESP32S3 only, not for the standard ESP32. So you have to select the correct board. ESP32S3 Dev module is the good starting point.
I have a similar problem with: **CrowPanel 3.5"-HMI ESP32 Display 480x320 SPI TFT LCD **.
I get the
when I compile it with the E_SP32-WROMM DA_ . When I set it to ESP32S3 _ I get the _wong chip error because it is not a esp32s3.
What can do?
Hello @xiaojun ,
For the CrowPanel 3.5"-HMI ESP32 Display 480x320 SPI TFT LCD, please use the TFT_eSPI library as the display drive. Please refer to: https://wiki.elecrow.com/index.php?title=ESP32_Display_3.5-inch_HMI_Arduino_Tutorial
