The basic lora gateway issue
I can not connect to wifi of basic lora gateway module. This module with black box and ssid ELECROW-GW1C. I am not successful with PC or Phone or Laptop.
  • Hello @ramazanali ,
    Please try to add letters to the password and see if that solves the problem
  • Thank you, it solves the issue.
  • I have same issue. What letters did you add? I used 12345678 as advised on the screen
  • There is no LED light flickering on lan cable socket when I plug it into router either.
    I see the gateway on WIFI but password 12345678 is rejected
  • Hello @davet999 ,
    Passwords with only numbers do not work. You can add any letters to your password
  • edited October 4
    I too have this same problem that the password "12345678" does not work. I have tried from my iphone and my laptop, I have also tried adding letters to it and "a12345678", "a12345678a", "12345678a", and "a1a2a3a4a5a6a7a8a" all do not work. I even tried "12345678ELECROW" and it did not work. Please provide an example of a working password. I have also successfully connected my laptop to a local 2.4 Ghz wifi network just to be sure my devices do support the 2.4Ghz band. Thank you
  • Hello @farnsaw
    Have you uploaded the code to the Gateway module according to this wiki https://www.elecrow.com/wiki/lora-basic-gateway-module.html?
    Please note that after uploading the code, please press the BOOT button for 3 second.
